Alrighty - I'm going to be the proud owner of some Porterfield pads soon.....
does someone have directions on how to put them on? or is it a fairly self explanatory deal? I've changed pads on an old 78 Corrolla, but this may be a pit more involved.
Thanks.
Thanks.
If you've done this before, then it should be fairly easy
The only thing you'll have to deal with is how to close the circuit on the brake pad wear sensor, so the warning light goes off on the dash. obviously the porterfields do not have wear sensors
Translation : - ) cut the wires off the OE pads and splice the two wires together.
Bundle up the excess wire and wire tie it to the strut bracket.
Be careful not to scratch your calipers with the retainer spring. File or grind down the leading and trailing edges of the new pads and use anti squeal (glue) to lock the pads to the pistons.
PS. If you're changing the back pads and you need to move the piston back into the caliper bore. Make sure you rotate (clockwise) the piston. Do not simply force it in.
Just the fronts? I have a huge pair of channel lock pliers that I use. Others use a large "C" clamp
there is a tool you can buy in Sears, Pep boys, etc., that's specifically made for this.
If you're talking the rears, there is a tool for that. If your car doesn't have a lot of miles on it, the rear piston might not have moved enough to bother a new pad installation.
