Any Dahlback users have problems using the MOFO?
Old 09-12-2005, 04:36 AM
TonyStarkz's Avatar
Default Any Dahlback users have problems using the ****?
My block 032 never settled in properly and I kept changing MAFs thinking that was the issue. With the suggestion of boostedTT, I changed back to the OEM housing and lo and behold its perfect again. I used to have soft limp under WOT and now its perfect. My 032 settled to -2.4% when it used to go up to around 12-14. It could just be my car and me doing something wrong, hence why I want to know if anyone with the Dahlback chip is using the **** with no problems.
Old 09-12-2005, 04:59 AM
Rest In Peace
TTinCT's Avatar
Default you may want to check with Steve...but i know>>>
that Dahlback fueling requirements, and agressive tuning can be hit or miss with Steve's stuff....your programming just may be too agressive for the ****....
btw- you running a 4 bar FPR?
Old 09-12-2005, 05:32 AM
TonyStarkz's Avatar
Yes, I was running the 4 bar...it seemed as though it was just too much fuel.
Old 09-12-2005, 05:39 AM
Rest In Peace
TTinCT's Avatar
Default so, with the ****, and the Dahlback chip>>>
you were running a 3bar??? If so, that is your problem...lean conditions. 4 bar would prevent that, or an adjustable FPR....the car may run a bit rich, but that is to prevent detonation, and it is only on the top end. Do you have any VAG run numbers with a 4bar?
Old 09-12-2005, 05:45 AM
TonyStarkz's Avatar
No, I ran the **** w/ the 4 bar. My VAG 032 blocks varied around -12.4% to -14%
Old 09-12-2005, 06:30 AM
artinmoTTion's Avatar
I've not had this problem (APR software + 4 bar, TTDA/**** + DB manifold), runs great.
Old 09-12-2005, 06:35 AM
Rest In Peace
TTinCT's Avatar
yeah..but the DB chip is pretty agressive...running 25psi or so IIRC.
Old 09-12-2005, 07:03 AM
TonyStarkz's Avatar
Hence why I was targeting specifically Dahlback chip users...everyone else seems to be ok
Old 09-12-2005, 07:45 AM
AudiWorld Uber User
TTschwing's Avatar
Default Dahlback must run very rich..>>
with those numbers. A/F's I have seen would seem to confirm. Try with a 3 bar and see if it doesn't come back in line...
Old 09-12-2005, 07:52 AM
TonyStarkz's Avatar
Good idea! I'm going to wait till I install my wideband and Adj FPR just to be safe..thx steve!
Quick Reply: Any Dahlback users have problems using the MOFO?
