Anyone installed their KW's and been able to lower the rear more than1"?
It's not noted in the instructions but when speaking to KW - they stated it should be removed. It will allow you to go to about 1.5" lower. I had mine set at 1.25" inches lower than stock. Also - measure from the fender lip to the center of the wheel for a more accurate measurement.
i see a black base which can't be more than a 1/6" thick. on the other hand, it looks like adding some threading to the shock might allow the perch to be run up another 1/4" or so.
