Anyone know how to get the concert out, tried everything ...
and now the stereo wont turn on, I only put two pieces of metel into the holes to release it, but the darn thing wont budge...any ideas..
One in each slot and simultaneously "splay" them out wards and try and wriggle the unit out using the cassette slot.Its awkward but doable..Once you get it out you'll see the mehcnaism for holding it in and will undertand better for next time you remove it.
Marcus
Marcus
Radio, removing and installing
Notes:
Obtain radio anti - theft coding before removing.
<img src="http://albums.photopoint.com/j/View?u=1524173&a=13620968&p=52840766">
Special tools, testers and auxiliary equipment required
Radio release keys 3344
<img src="http://albums.photopoint.com/j/View?u=1524173&a=13620968&p=52840768">
Insert release keys (special tool 3344) into front of radio as shown.
Left side: "Top L" facing upward
Right side: "Top R" facing upward
- Remove radio from dash panel.
- Unplug connectors and antenna wire.
Installing
- Remove release keys from radio.
- Plug in connectors.
- Carefully slide radio into dash panel and engage in mounting frame.
- Activate anti-theft coding (see Radio Operating Instructions).
You're welcome.
Notes:
Installing
You're welcome.
radio as your diagram shows but from the sides. Maybe some of the radios are slightly different.
<img src="http://pictureposter.audiworld.com/7403/radio.jpg">
2 holes (vertical alignment) on each end of the radio. You use a U shaped tool (coat hanger works) to release the internal tabs on the DIN bracket. You might have an older design.
Call them and ask them to send you the Becker Radio Removal tools (used for Mercedes - they're the same ones). They're $2.80. (+ $5-$10 for shipping, depending on how fast you want it). (877) 407-2950
is continental imports # - they're very nice and knowledgable.
Autotoys.com also sells similar tools for a bit more - they're three way tools and work in lots of different vehicles, but it's more expensive, and autotoys customer service is TERRIBLE.
I also shorted something when I tried it with a non-standard tool. It had blown the 5amp fuse on the back of the unit - it's a standard auto fuse, available anywhere.
For some reason, even after I disconnected it and reconnected it, it didn't need the radio code! But make sure you have it handy, just in case.<ul><li><a href="http://www.continentalimports.com">http://www.continentalimports.com</a</li></ul>
