Anyone want to swap 20mm spacers for 8mm spacers?
Kahn RSR's with 37 offset. Temporarily I have moved my 25mm from the rear to the front.
I put the 8mm's on the rear for now. With the 25mm spacers I clear the Stoptechs by 9.8mm. Consequently, I could get by with 17mm spacers but I would feel better with 20mm spacers.
Gotcha...20mm will be fine on the front. 17mm offset in front is pretty aggressive...
what size tires are you running? Some tire brands of the same size will vary in width. So there may be a chance of rubbing on the fender. If any rubbing will occur, it'll be on the inside rear portion of your wheel well.
