Arb Install Advice Needed
Putting Hotchkis arb's on 2001 quattro with stock shock/springs (haven't decided on suspension yet). Is it necessary or advisable to change the front and rear sway bar links? If yes, is there a recommended part (r32 fronts?) or aftermarket supplier?
My fronts started clattering at approx 80,000 mi. Rears are still good at 94000.
You will like the Hotchkiss bars. Grease them well as you install or they will squeak. I run my rear bar in the middle hole and front bar at the softest (outer- longest) hole. I have Koni Yellows, Defcon control arm bushings and stock springs.
Mike
You may find that the Borla requires considerable tweaking to get it to hang straight and tuck up close to the valance. Mine did. Even required cutting and rewelding the muffler inlet pipe. It is perfect now, and I like it (except on long trips) but it was not plug and play. I did get mine on a special price reduction for about $475. a few months back so maybe they had some that were not quite true. The advertised special did not say that however.
JimR
Audi A3 / S3 / RS 3
9
09-14-2008 04:47 PM
2point7LI
01-22-2008 08:12 AM
blueT28EnYcEe
04-06-2002 03:27 PM
