Audi TT 180 FWD Turbo upgrade recommendations?
basically bolt on...no weird issues afterwards...i don't want to be tinkering around for days trying to figure out lil inconsistancies...
thanks for your response...
I have a 1st ed TT which is a 180FWD. With a few mods, including APR I am comfortable with my performance as I am not concerned about being the fastest as much as a reliable sports car with some juice when I need it. So it depends on how much you want to invest as the 180 has limits, plus more advanced models have been introduced (2001, 2002......2008). Just my 2 cenTTs.
and a couple other little pieces ![Smile](https://www.audiworld.com/forums/images/smilies/smile.gif)
rock solid reliable after 75k.
just a K04 and software would only be about $1500 or so plus labor to install. good enough place to start...
the nice thing about fwd is the install is much easier, there's down pipes available and lots of other stuff to bolt on later. have fun
If you are going for 300+whp stay away from K04 uprades,not worth the time/money unless you are doing the 225TT K04...I have done K04 upgrade
before and the owner as well as I were dispappointed with the negligible increase,the 225K04 is good to 260-270hp so you will have better results with THAT KO4.For my car,TT180FWD,I installed a ATP GT2871R turbo kit,REVO big turbo software,good IC and exhaust setup and @26+28 psi made 355 and 381 whp.
Car is daily driven,no CEL and other than burning out the stock clutch,has been faultless.
Since your car is a FWD the VW/Golf turbo stuff fits right in,and so far I have 14k miles on my car,and run 26psi boost daily,so far so good!
If you build it correctly,it will be powerful and reliable.....plus we don't need to worry about the weight and complexity/failure of the rear suspension/Haldex/diff.
if you pay a shop (that's you, right?) to do the install correctly (and nothing in the writeup is unrealistic or unexpected), he may as well spend the money on a complete package (my guess on the ATP/Revo is $2600 give or take), not including the labor - my guess there is the ATP is at least 1.5x the labor of the APR, but 'to each..' and all that.<ul><li><a href="http://forums.vwvortex.com/zerothread?id=2774798">Joe@vwvortex passed on this link; read all 3 parts</a></li></ul>
Yes,I agree,if your mechanical abilities
are "average" then even the APR kit may be a struggle.The ATP kit was easy to install (for me),but since I do not use any APR products,cannot comment on their turbo kit.Either way,it has been tried and proven,so APR may be the right choice for the DIY.But be prepared to pay for the priviledge!
Excelerate
TT (Mk2) Discussion
10-15-2013 11:34 AM
I have a 180hp TT, can I install the turbo from the 225hp on it. Will it fit? Do I need any extra co
Mat-TT
01-23-2007 04:16 PM
James.L
02-14-2001 06:56 AM
