Back to the grind of a solution---getting better
Evan you were right found TWO air leaks on intake side now runs smooth with no cells BUT no Boost or Vac. Could it be N75 as when you found that broken wire with Intermittant current maybe damaged valve ? Any way the yellow wire on the N75 has constant power to it even with ing off ? mine does? Oh the mysteries ontrying to think oneday I'll get it right!!
Your Gauge is either bad or your hose to the "T" fitting is crimped or busted. The engine will ALWAYS have vacuum at the manifold at idle. If the hose from the N75 to the wastegate is bad you'll have an overboost situation and I don't think that's your issue..
The N75 has absolutely NOTHING to do with normal idle or any running for that matter when not on boost
for boost Runs as a N/A car turbo is doing nothing Block 115 said call for boost is trere but not making any. Guess when I did work must have pulle something loose and now I CAN NOT FIND IT
I assume you're hooked to the FPR line?....That hose goes directly to a nipple under the manifold. And that braided line is known to deteriorate. This means your fueling is not being ramped up when boost is called for which is a whole nother problem. You've STILL got something off or disconnected..
Still pondering on low or no boost on my car..Hoses looks ok.Can a broken DV or N75 caused it??.....
Bolo
07-08-2007 03:04 AM
maTTyaudi
04-05-2006 05:01 PM
TTTEXAN
09-23-2005 05:18 AM
escargot
Performance and Tuning
9
05-26-2004 01:13 PM
