Bad steering feel after tire change...
Help, I need to know that I'm not crazy. I just had my dealer replace my worn RE040's with a new set of S-03's. They performed an alignment as well.
There were three problems apparent when I picked up the car. First was that they overinflated each tire by 10 to 13 psi, which of course I took care of. Next was vibration through the wheel at 60+ mph. Third was dead or numb steering feel on center. At speed, the wheel can be moved a bit without turning the car, which feels awful and not like the car that I dropped off.
I brought it back, and they balanced the wheels (again?) They also told me that the tech drove it and found nothing wrong with the steering, and that these tires are soft, and that would explain the different feel.
The vibration is gone, but the steering remains wrong. So, they're feeding me a line, right? Why would new S-03s feel worse than the old stock tires? I've been to this dealer three times in a month, and I'm disgusted with their service department.
Thanks...
Jason
2000 180TTQ
(Need to make a sig.)
Thanks...
Jason
2000 180TTQ
The softer tire should make it more responsive so the dealer is not explaining matters correctly. Have they checked the steering wheel and suspension? Is wheel centered? Sometimes the alignment won't be done correctly. Have a friend try it or try out another TT member with the same tires - but should not feel numb.
