best glue to use to reglue headlight housings?
i'm trying to make sure i get this mod right the first time, and i'm worried the existing glue is not going to be sufficient to get a proper seal around the headlight.
can someone recommend a specific product that i could use to reseal the headlights, and where to buy it from?
thanks!
thanks!
I think just about everyone that's done this mod just re-uses the glue. Have you taken your housings apart yet? The glue is pretty industrial.
There are 4 black clips that hold the clear lense to the back housing.I used some light clamps to get them close.(Nothing w/ too much pressure cause you don't want to damage the lense) I don't believe the headlights are airtight from the factory.Not a big deal if you can find some & it makes you feel better to have it.
just finishing up the last one now. reusing the glue just seems a bit ghetto to me, and if it doesn't work i'll have to pull the whole bumper off again to fix it, which is serious pain.
