Blinker relay replacement... Piece of cake
Old 09-26-2006, 09:47 AM
  #31
New Member
Courtneyags03's Avatar
Default Re: Blinker relay replacement... Piece of cake
I am having problems with my blikers also. I am planning on buying the blinker relay but I am not sure of exactly what to buy. Is this the one that has the hazard button attached to it? Please help.
Old 10-03-2006, 11:06 PM
  #32
ljun's Avatar
Default how much is the relay?
does anyone know how much the relay costs to buy? either via dealer or third party?
Old 01-06-2007, 11:09 AM
  #33
New Member
Default Alternative Radio Removal Tool
I went to Best Buy to have them remove my radio. They did not have the tool for my 2001 Audi TT. I researched and found out that it is the same tool used for the VW Bug. So, they used that one and it worked perfectly.
Old 10-21-2008, 05:22 AM
  #34
New Member
JEDubz's Avatar
Great write up. If I had to add anything I would mention that this is much easier with a flashlight and that the lever you pull down to release the switches does not just move up and down but front and back so make sure to feel where it clips in. I struggled with mine for almost 20 minutes before I realized this.
Anyways, thanks again! I've successfully done my first Audi repair. Woot!
Old 01-20-2009, 01:00 AM
  #35
ellipsis's Avatar
Dear Sir,
I want to thank you for the instructions. I absolutely love this forum and this community. I just replaced the relay... and with your post - it took just 20 minutes... it would have taken 15 but I did struggled with the radio key a bit. Again, I thank you. By the way, the stealer wanted $480.00 for the repair... ha ha ha!
Old 04-29-2009, 03:27 AM
  #36
JettaRedII's Avatar
Worth a bump to the top!
Old 11-26-2009, 12:35 PM
  #37
VanceSF's Avatar
Default Snapping the lever back up into place
I had a lot of difficulty with this. Actually I missed this step the first time around as only the left side unsnapped. A month later when my left seat warmer control punched into the dash did I realize I had a problem.
Apparently, there are 2 places where this lever snaps in and out. When you unsnap both of them, the bar is obviously hinged and freely moves. They seem to be 3/4 to an inch from each end. Using both hands I was able to get both snapped into place at the same time. (I had no luck snapping them one at a time.
Thanks to the original poster. You're clear instructions were really helpful.
Old 12-02-2009, 10:17 PM
  #38
bobkay's Avatar
My relay came apart easy enough, just a little corrosion on the contacts.
Old 12-03-2009, 11:40 AM
  #39
Herzogzwei's Avatar
Default Radio tools
I got my radio removal tools from Walmart for around $5 in the automotive section next to the car stereos. They work just fine.
Old 02-19-2010, 11:13 AM
  #40
levdeb's Avatar
Default great writeup!
Got my relay for $48 at genuinevwaudiparts.com. Installed in seconds thanks to you!
Quick Reply: Blinker relay replacement... Piece of cake
