Boost Pressure via Vag-Com?
VAG will measure Command (what the ECU wants), IC (MAP sensor or what it's actually getting) and Manifold (a not real calculated number from the MAF). There is also a limitation of 2550 milibars (22.5 PSI) from the MAP sensor reading.. Real and true pressure at the intake manifold can only be measured by a gauge...
For instance...Here's a baseline on a moderately modded car (Mine at the time):
<img src="http://images25.fotki.com/v898/photos/7/7305/130918/pressures-vi.jpg">
Removing the MAF screens returns this data...see how the calculation varies the manifold pressure readings? This was not a real boost increase, but rather a flow increase that skewed the numbers.. What you see is not always what you get in other words...
Oh yeah, it measures in Milibars...Subtract 1000 or your actual atmospheric pressure to interpret in Bar..(1 Bar = 14.5 PSI)
<img src="http://images30.fotki.com/v477/photos/7/7305/130918/MAFscreenout-vi.jpg">
javedikian
11
03-12-2020 04:39 AM
Distinct
03-06-2006 09:39 AM
jatava
06-10-2004 09:32 AM
ArandA4
05-06-2003 08:30 AM
AbnormallyAspirated
04-29-2001 03:09 PM
