Braking in snow
Old 01-02-2001, 06:35 AM
New Member
lemonTT's Avatar
Default Braking in snow
Driving around this weekend in the snow, I found it very difficult to stop both in deep snow and lightly dusted streets. When I first got my TTQ last winter, I experienced the same problem and was told by Audi that the brakes needed to be "broken in". I know my TT has ABS, but surely the brakes are not suppose to pump that much?
Comments?
Old 01-02-2001, 06:37 AM
New Member
Avanti Quattro's Avatar
Default Re: Braking in snow
What tires are you running? The original Potenza RE040 tires do not have a snow rating.
Old 01-02-2001, 06:39 AM
BZ
Junior Member
BZ's Avatar
Agreed. Everyone says the RE040 are really really bad in the snow. This weekend I found I was pretty secure on the road but I would certainly think twice about snow tires if I actually HAD to drive it.
BZ
JustJeff's Avatar
snow tires, snow tires, snow tires, snow tires, snow tires, snow tires, snow tires, snow tires,
Old 01-02-2001, 06:40 AM
Elder Member
Larrytt's Avatar
Default Unfortunatley that is the way our "wonderful" ABS system works .. .
pathetic isn't it? I have my ABS checked out EVERY time I have a service done. So, it has been checked 6 times at 3 different dealers. They have said the ABS works fine.
I don't believe it to be honest. Mine is constantly coming on, even when it is dry out! I read on another forum that you can turn the ABS off by pulling the correct fuse. I am going to investigate that to see if the braking in the snow and the dry improves or not.
Old 01-02-2001, 06:42 AM
Elder Member
Rennen's Avatar
Default Hey Jeff, wanted to ask you about this post...you're not selling are you?
Man...perish the thought...
<a href="https://www.audiworld.com/forum/m.new/tt/msgs/169653.phtml">https://www.audiworld.com/forum/m.new/tt/msgs/169653.phtml</a>
Old 01-02-2001, 06:46 AM
Gnowknayme's Avatar
Default That doesn't sound right to me.
I mean, I'm no expert on ABS or anything, but I know how often my ABS comes on. I've NEVER had the ABS come on when the roads are dry or wet. It has only come on when there's snow or ice on the roads, and when it does, it does exactly what it's supposed to: stop the car without sliding all over the place.
I dunno...Maybe you brake a lot harder than I do, but I've never had ABS come on while on a dry road, even when braking pretty hard.
Old 01-02-2001, 06:47 AM
BZ
Junior Member
BZ's Avatar
Larry... did you do your "Sig Card" in Photoshop?
Old 01-02-2001, 07:08 AM
BZ
Junior Member
BZ's Avatar
Ok.. I like it! Is this flattery?
Junior Member
Ebb Vicious's Avatar
Default you guys must brake really hard or something..
mine have never come on unexpectedly,.. and i drive hard.
...dave
Quick Reply: Braking in snow
