Break rotor relacement on a 2006 3.2
Can anyone give me advice on replacing my front and rear rotors with aftermarket drilled or slotted ones? And can you replace the rear with a bigger caliper? I plan on using my front caliper and new brake pads. Thanks for the info.
But if you must spend the money for aftermarket, however unneccessary it might be, try Achtuning. They are in Washington.
www.achtuning.com
www.achtuning.com
<center><img src="http://pictureposter.audiworld.com/34314/beetle_1lap20_race206.jpg"></center><p>
but only in conjunction with 6 piston front calipers. If you want to keep your original front calipers, then the rears are best kept too, to maintain brake bias. You can upgrade just your rotors, while retaining your OEM calipers. Try Zimmerman, Brembo, ECS Tuning, others....<ul><li><a href="http://www.ecstuning.com/stage/edpd/pagebuild_v2.cgi?make=Audi&engine=3.2L&mod el=TT&submodel=Quattro&category=Braking&am p;subcategory=ECS%20OE%202%20Piece">ECS 2 piece drilled/slotted OE replacement rotor</a></li></ul
forced2induce
40
01-16-2006 09:42 AM
qua4ttro
11
03-09-2003 07:17 PM
Singletrack
11-08-2002 01:19 PM
CP
12-15-1999 01:23 PM
