Brightest Fog Lamps
One side of relay contact goes to fused 20A wire, right to the battery, for example.
Other side of relay contact goes to white fog wire, back of headlight.
Relay Coil
One side goes to ground.
Other side goes to wire in headlight harness that used to go to the fog light bulbs.
this way you can easily switch higher current to the existing fog light socket, without worrying if you will burn out any OEM switch or other wires. You do not stress any in-dash fuse or wires. You do need to add in some in-engine compartment wiring however.
simple.
<img src="http://www.radioshack.com/images/ProductCatalog/ProductImage/275/275-226.jpg">
Relay Coil
simple.
A6 4.2/S4 Portlnd OR
03-17-2007 07:05 AM
hollyane
03-06-2006 12:16 PM
A4 Pilot
08-29-2002 03:00 PM
Richard Solomon
08-08-2000 03:51 PM
