Calling Cruzad3r & Schwing. Here is my first shot at the "Butt Dyno" results........
Old 03-13-2008, 04:43 PM
  #11
BlueChip's Avatar
Default I was full of gas (ahem) so that's about 5 gal more = 40 lbs so......
I'm really close at 3442 lbs with driver and a full tank.
Thanks a lot John that confirms that part of the calculation.
BC
Old 03-13-2008, 05:05 PM
  #12
Cruzad3r's Avatar
u send me an email? so I have your email
Old 03-13-2008, 05:10 PM
  #13
BlueChip's Avatar
Yes I did.
Old 03-13-2008, 06:51 PM
  #14
Cruzad3r's Avatar
got it..send you my sheets tomorow
Old 03-14-2008, 08:14 AM
  #15
Audiworld Premium Sponsor
Andy@Ross-Tech's Avatar
Default Nice work!
FWIW, I think I recall playing around with polynomial trendlines but found that it affected "peak" numbers since it made the data TOO smooth. I wish there was some standardized performance comparison for "area under the curve". :-)
Also, if you are at all handy with GUI design/etc, feel free to make an easier to use version of this. Very few people (maybe 20-30) have actually used this method, presumably due to the clunkiness of all of the Excel manipulation.
Andy
Old 03-14-2008, 08:15 AM
  #16
Default One more thing ....
You should get a much faster sample rate by selecting only one measuring group while you are logging. I'd expect to see about 3 samples/sec that way.
Andy
Old 03-14-2008, 11:36 AM
  #17
BlueChip's Avatar
Default You're absolutely right Andy......
The only way that I was able to increase my sample rate was by going to only one group (005). Changing the Blk Int from 55 to 25, and the Char Int from 1 to 0, had no effect on the sample rate.
I am going to send you an e-mail with Cruzad3s data which he sent me and you can see the difference between your "smoothing" approach and my velocity "fitted" approach.
I have run both 2nd & third gear tests and the HP & TQ increased from 221HP/195ft-lb to 227HP/228ft-lb respectively.
I have not run a 4th gear run because of the speeds required (if they catch me they would throw me in jail) but Cruzad3r has and he gets significantly higher HP & TQ values in 4th than in 3rd. Is this to be expected?
BC
Old 03-14-2008, 11:40 AM
  #18
BlueChip's Avatar
Default Thank you Andy.......
I'm not a computer geek. I can't even spell GUI. But if someone out there is handy with it I can help them. Everything I've learned about Excel & PowerPoint, etc. I've learned the hard way....Trial & error, with emphasis on the error.
BC
Mike@StartupRacing
Pacific Northwest Discussion
13
05-03-2007 08:26 AM
4Rings::G2 boosted::
Mid Atlantic Discussion
01-22-2006 06:45 PM
MarkFank
11-28-2005 11:59 AM
TheSleeperS
76
01-09-2005 11:29 AM
ARC Studios
42
01-08-2005 02:33 PM
Quick Reply: Calling Cruzad3r & Schwing. Here is my first shot at the "Butt Dyno" results........
