camber question
after searching the archives i cant come up with a conclusion. for coilovers should i:
1. 1/2 KMAC (could i get away with this)
2. Full KMAC
3. adjustable control arms
oddly enough some shops including vw/audi tuners have said that i wont need camber correction at all? huh? lol kinda confused here...
thanks for the help!
2. Full KMAC
it really depends on what level of adjustablility you want. The best bang for the buck is full Kmac. You get the greatest level of adjustability for the lowest cost. 1/2 Kmac will work on limited drops of 1" or less IF you spec to 1.6 or 1.7 degrees of negative camber and want to stay at a relatively agressive rear toe setting. If you want less negative camber than that - you'll need to go to adjustable control arms on the bottom. That should give you the ability to set it at a relatively agressive negative rear camber AND still get within spec on rear toe.
I'm running Forge adjustable rear arms on the bottom and have a max spec on rear toe and 1.7 degrees of negative rear camber.
other shop telling me true? that i dont need anything at all? i find that hard to believe. i do not plan on tracking car. its a daily driver. what is your take on this?
if you lower without adjustment and toe will be way off as well. Not really a problem is you like your rear tires to last 5k miles :-)
ECS Tuning-Audi
S4 (B8 Platform) Discussion
06-14-2019 06:44 AM
ECS Tuning-Audi
A4 (B8 Platform) Discussion
06-14-2019 06:44 AM
