Can anyone tell me exactly what the 40K service consists of?
At 40,000 Mi (64,000 Km)
Engine Oil - Change the oil.
Engine Oil Filter - Replace the oil filter.
Engine - Check for leaks.
Cooling System - Check the coolant level. Add coolant if necessary.
Exhaust System - Check for damage and leaks.
Engine, On-Board Diagnostic - Check Diagnostic Trouble Code Memory. Purge if necessary,
where applicable.
Doors - Lubricate door hinge mechanism.
Battery - Check electrolyte level. Add if necessary.
Windshield Wiper and Washer - Check fluid level. Add fluid if necessary.
Manual Transmission - Check gearshift mechanism and clutch for proper interlock operation.
Tires and Spare Wheel - Check for wear and damage. Check the pressure.
Service Reminder Indicator Display - Reset the display.
Brake system - Check for damage and leaks. Check thickness of pads and brake fluid level.
Drive Shafts - Check the boots.
Road Test - Check braking, kick-down, steering, electrical, heating and ventilation systems, air conditioning and power accessories.
Lights - Check the lights.
Front Axle - Check dust seals on ball joints and tie rod ends. Check tie rods.
Haldex Clutch - Change oil and filter.
Power Steering Fluid - Check fluid level. Add if necessary.
Dust and Pollen Filter - Replace filter.
Headlights - Inspect headlights. Adjust if necessary.
Air Cleaner - Replace filter element.
Spark Plugs - Replace the plugs.
where applicable.
billy2001Q
11
03-08-2005 04:55 PM
mrvirgilg
01-27-2005 12:45 PM
