Can someone tell me what the following codes mean?
16806: Main catalyst, Bank 1: below threshold
17743: Engine Torque Monitoring 2: Control limit Exceeded (Sporadic)
Thanks
Thanks
Re: Can someone tell me what the following codes mean?
Try the link below with each code ... manageable number of hits for each code to read about (~20).<ul><li><a href="https://www.audiworld.com/search/">Click</a></li></ul>
17743: Engine Torque Monitoring 2: Control limit Exceeded (Sporadic) means...
You are boosting too high. You boost is over the requested amount of boost. I had my car vagged yesterday and that is what popped up. You need to turn down the boost. Hope this helps.
Probably sporadic spiking....>>
Your high flow exhaust is probably allowing the turbo to overspool a bit. A boost machine will tame this...(it's not just for enhancing boost, but for smoothing out all the other mods that affect turbo action)
Kingttr
08-13-2006 11:59 PM
1SeriousPig
15
09-05-2005 03:23 PM
Imola4
VAG-COM Discussion
10-29-2004 02:04 PM
