Can someone who has had his or her longitudinal acceleration sensor replaced look up the part number
for me? The parts guys at the dealership are IDIOTS and have no idea what this part is or what it is supposed to do (even after I attempted to explain the different sensors and components of the ESP system in simple terms). So they can't find the part until I come back with a part number.
I went after work the other day. They couldn't even locate it in the diagrams. They asked if I had actually seen the part. All I know it is located under/behind the glove box, and mine is bad (as indicated by the ESP and ABS lights and the DTC I am getting with a VAG scan). I don't want to remove the glove box until I have the replacement part in hand, ready to go in.
The dealership closer to my house is typically more competent, but I can't get there during the week before they close.
OK Now I remember. I am a bit tired today. I scanned my car a week ago because the ESP light was coming on, CAG said something about a lateral ABS blah blah, but basically my battery is bum, wont hold a charge at all, going to dealer today. Having a lot of other electrical issues,
I find myself really worried when I can out-tech-speak people at a dealer that actually get paid to do this.
Prior to chassis number 8N-2-014 401, the sensor was split into yaw - 1J0 907 657 A and accelleration - 1J0 907 651 A, after that chassis number, it's a combo sensor and is 7E0 907 652 A for quattro (should be yours) and 7E0 907 655 A for FWD.
For your parts guy, it's in group 9 subgroup 27.
This is the code I got:
Address 03 -------------------------------------------------------
Controller: 8N0 907 379 E
Component: ESP 20 CAN V005
Coding: 18446
Shop #: WSC 01236
1 Fault Found:
01279 - Longitudinal Acceleration Sensor (G251)
27-10 - Implausible Signal - Intermittent
From the Bentley repair manual:
Longitudinal acceleration sensor -G251-, removing and installing
Removing
- Remove glove box:
Repair Manual , Body Interior, Repair Group 68; Trays, compartments and trim
- Unplug electrical connector -2-
- Use a screwdriver to pry mount off longitudinal acceleration sensor -arrows- and remove sensor -G251- -1-.
Note: The longitudinal acceleration sensor is not resistant to shocks or impact.
Do not install a sensor which has dropped to the ground otherwise proper operation is not ensured.
Installing
Install in reverse sequence; note the following points:
- Initiate basic setting for longitudinal acceleration sensor -G251-.
<img src="http://www.msu.edu/~lytleric/sensor.gif">
Coding: 18446
Shop #: WSC 01236
1 Fault Found:
Removing
- Remove glove box:
Installing
