car completely dead
My 02 TT is completely dead. can't lock/unlock the door with the remote, alarm light not on. try to start the car, nothing happen not even the clicks. nothing come on when I put the key in on the dashboard. Is the battery dead?
Get a voltmeter and check see if you have 12+ volts at the battery terminals.
How long since you have driven the car? If the car is parked and never driven , under normal circumstances the battery should last 6 -8 weeks before it dies.
It should be 12 volt (usually 13+ quite often), buy or borrow a charger and try charging, then measure again. If it's that low it needs at least overnight charging.
Expect the charger to go to at least 8 amps as soon as the charger is turned on then fall back slowly. If after a couple of hours it's hardly drawing any current your battery is "not long for this world".
Most auto stores can check the battery but it needs to be fully charged before they can do that.
if there is a warranty on the battery (and good batteries come with at least 36month warranties) it should cost you next to nothing to replace it...
Anything less than 12.4 coming out of a battery on the TT and the car will have some odd electrical gremlins....it is very sensitive to electrical...
91quattro
06-17-2017 11:36 AM
A8Pete
9
07-18-2016 09:00 PM
awdinut
10-23-2015 11:04 AM
