Car pulls to the right, whats wrong? :-) , try to keep it at a fairly serious level.... please....
Tire pressure ok
The car pulls to the right when i press down the clutch/when i neutral....
What should be adjusted/changed?
It only pulls right when the clultch is depressed?
That makes no sense considering the clutch and tranny have nothing to do with steering the car. hmmm
When shifting gears do you feel a tug on the steering wheel to the right with each gear change? Or do you have to have the clutch depressed for a period of time? What if you just move the shifter into neutral without pressing the clutch, does it pull then?
Have you tried switching tires front to rear? Do the left side first, and see if that makes any difference. If not, then change the right side. The reason I said the left side first is the left would/could have more of an impact on turning the car right.
Something just occured to me...
Most roads are crowned in the middle to allow for rain to run off to the sides. Perhaps that contributes to the phenomenon? Try to replicate the action in big parking lots and see if that helps.
Jeff 'S iv
11-28-2008 04:20 AM
AudiJon
07-27-2004 11:35 AM
TheDetailGuy(666PSI)
03-13-2004 02:11 PM
LCP
10
09-27-2001 10:52 AM
