Car will not run with MAF plugged in.
Massive misfires, struggles to stay running at idle then dies... lots of popping and carrying on.
Car died on the way to Ace and we managed to nurse it into the parking lot. Same symptoms as above. I unplugged maf when we got into the lot just for ****s and grins and never plugged it back in. We assumed coil packs and swapped 1 and 2 with spare AMU coils. It ran good after that actually.... although I went really easy the entire way. It made it home.
Get into the garage and put the VAG on it. It logged misfires on 3 and 4. Remember we swapped out 1 and 2. I thought it was odd it was running so well if 3 and 4 were the bad coils.
Then I remembered the maf was unplugged so we shut the car off, plugged the maf back in and started it back up.
Same thing as before... barely runs, misfires, popping, idle all over the place, stalling etc.
Obviously the maf is bad... yes?
Are these symptoms normal for a dead maf though? John's had two die and his did nothing of the sort.
Im going to get 4 coilpacks and a new maf tomorrow... but is there anything else I should look at?
recommend in future to go with all new coilpacks instead of just failed ones...remember they are electric and can wear unevenly.....fwiw
