Central Locking Issues VAG-COM scan inside
2000 Audi TT FWD engine code AWP
It has a number of electrical issues, but trying to tackle one at a time. Currently trying to diagnose the central locking system. Next will be the dying instrument cluster...
Symptoms:
1) doors will not lock from inside the car - not by using the door lock button, or after reaching 15mph
2) doors will not lock/unlock with the keyfob - must use the key-in-door to lock/unlock both doors
3) (i believe this is related to the electrical components in the pass. door latch) pass. window will not move up/down 1/8" to create a seal; driver's window does
Here is what my scan revealed. I believe it is all related to the central locking module and trying to determine if there is a way to fix it without replacing the part. Also, wondering if anyone else has run into this problem and how it was resolved. Dug a bit online to see what this part would cost to replace, but can't seem to find this part for sale online and would rather not get ripped off by a dealer, so any help with where to find the part for a good price would be great.
On with the codes:
Wednesday,03,February,2010,16:27:58:17116
VCDS Version: Release 908.1
Data version: 20091018
Chassis Type: 8N - Audi TT
Scan: 01 02 03 08 15 17 22 35 37 45 55 56 76 77
Address 01: Engine Labels: None
Part No: 8N0 906 018 C
Component: 1.8L R4/5VT G 0003
Coding: 06500
Shop #: WSC 01236
No fault code found.
Readiness: 0000 0000
Address 03: ABS Brakes Labels: Redir Fail!
Part No: 8N0 907 379
Component: ASR 20 IE CAN 0001
Coding: 13204
Shop #: WSC 01236
Address 08: Auto HVAC Labels: None
Part No: 8N0 820 043
Component: TT-KLIMAVOLLAUTOMAT D02
Coding: 00140
Shop #: WSC 01236
Address 15: Airbags Labels: None
Part No: 8N8 909 601
Component: Airbag Front+Seite 0005
Coding: 10102
Shop #: WSC 01236
Address 17: Instruments Labels: Redir Fail!
Part No: 8N1 919 930 B
Component: KOMBI+WEGFAHRS. M73 D09
Coding: 02244
Shop #: WSC 07115
No Faults Found
or DTCs not supported by controller
or a communication error occurred
Address 35: Centr. Locks Labels: 8Nx-962-267.lbl
Part No: 8N8 962 267 A
Component: Central Lock/Alarm D04
Coding: 15884
Shop #: WSC 01236
10 Faults Found:
01366 - Opened Due to Crash Signal
35-00 - -
01572 - Alarm triggered by Door Contact Switch; Passenger Side
35-00 - -
01370 - Alarm triggered by Interior Monitoring
35-00 - -
01369 - Alarm triggered by Hood Switch
35-00 - -
01616 - Signal Wire to Interior Monitor
36-10 - Open Circuit - Intermittent
00955 - Key 1
09-10 - Adaptation Limit Surpassed - Intermittent
01559 - Drivers Door
58-10 - Can't Lock - Intermittent
01560 - Passenger Door
59-10 - Can't Unlock - Intermittent
01617 - Please Check DTC Memory of Interior Monitoring
35-10 - - - Intermittent
Address 45: Inter. Monitor Labels: 8E0-951-177.lbl
Part No: 8N8 951 177 A
Component: Innenraumueberw. D09
Coding: 00001
Shop #: WSC 00000
1 Fault Found:
01463 - Alarm triggered by Sensor for anti-theft alarm System
35-00 - -
Address 55: Xenon Range Labels: 4B0-907-357-AUT.lbl
Part No: 4B0 907 357
Component: LEUCHTWEITEREGLER D003
Coding: 00009
Shop #: WSC 01236
Address 56: Radio Labels: None
Part No: 8N0 035 186 A
Component: Radio D03
Coding: 00517
Shop #: WSC 01236
No Faults Found
End ---------------------------------------------------------------------
Symptoms:
On with the codes:
Coding: 06500
Shop #: WSC 01236
Coding: 13204
Shop #: WSC 01236
Coding: 00140
Shop #: WSC 01236
Coding: 10102
Shop #: WSC 01236
Coding: 02244
Shop #: WSC 07115
No Faults Found
Coding: 15884
Shop #: WSC 01236
10 Faults Found:
35-00 - -
35-00 - -
35-00 - -
35-00 - -
00955 - Key 1
Coding: 00001
Shop #: WSC 00000
1 Fault Found:
35-00 - -
Coding: 00009
Shop #: WSC 01236
Coding: 00517
Shop #: WSC 01236
No Faults Found
..ok so further searching by part no. 8N8 962 267 A - rather than "central locking module", or some variation of that, has produced some results; however, still curious to see if there is a way to get this repaired or some recoding that may be able to be done with VAG-COM to fix this.
Also, if I do purchase a replacement, what is involved in the "after-installation coding process", or is that even necessary? I have read about ppl paying a dealer $200+ to recode it. I think it will have issues with the keyfob otherwise.
Thanks for looking.
Thanks for looking.
pj3346
01-11-2011 12:46 AM
chenisheda
10-02-2007 11:23 AM
OOOO_Circus
12-18-2006 06:52 AM
qksilverjc
08-28-2003 05:28 AM
