check engine light
Have a 2000 TT 180hp quattro that has a check engine light on, code states "engine is running lean, check for vacuum leak", could not find leak anywhere. Mechanic suspects a faulty mass air flow meter. Anybody out there have or had the same problem. The car only has 44k miles.
<center><img src="http://pictureposter.audiworld.com/24828/reinstal.jpg"></center><p>
the bottom is the housing.There are two torx screws.They can be taken out w/ a pliers if you don't have the appropriate tool.The top part w/ wires attached is a push & unclip deal. You can order the VW MAF housing & sensor for less $ at Impex Foreign auto parts.It's an easy install.
<center><img src="http://pictureposter.audiworld.com/24828/maf_comp.jpg"></center><p><ul><li><a href="http://www.vwparts.com">http://www.vwparts.com</a</li></ul>
QPower95
04-22-2010 12:26 PM
quattro100
02-07-2007 09:02 PM
