Check engine light came up, my mechanic says that is
Old 01-17-2006, 02:50 PM
New Member
I_love_my_car's Avatar
Default Check engine light came up, my mechanic says that is
the turbo valve, does he mean the Divert Valve?
Thanks
Old 01-17-2006, 03:14 PM
New Member
whoooodeeeknee's Avatar
Default What's the code it's throwing?
Haven't heard of code being thrown that pinpoints a DV as being bad.
Old 01-17-2006, 03:17 PM
New Member
mmm let me give him a call
Old 01-17-2006, 03:40 PM
blackfnTTruck's Avatar
Default Check engine could be anything from simple, gas cap not tight to..............
major problems, the major ones are not very common. MAF, mass air flow sensor is most common.
Old 01-17-2006, 03:41 PM
JohnLZ7W's Avatar
There's one that when read with a vag com actually says "Check DV!!"
Old 01-17-2006, 04:18 PM
New Member
Default This are the two codes P1173 and P1297
He says that the first one reads Clogged suction jet pump, but he cannot find it.
And the P1297 is about a valve
IS HE CORRECT?
Old 01-17-2006, 04:26 PM
Default Check this site out, plug in your MY and engine code, then........
select diagnostic codes and it will show you an explaination<ul><li><a href="http://www.ebahn.com/AUDI/A/A3/TT/">http://www.ebahn.com/AUDI/A/A3/TT/</a</li></ul>
Old 01-17-2006, 04:35 PM
New Member
Default I need a suscription for that right?
I mean for the full description
Old 01-17-2006, 04:55 PM
Yes for the full detail, but it does give you the short explanation.
Old 01-17-2006, 06:20 PM
Cruzad3r's Avatar
that is one kick *** site
Quick Reply: Check engine light came up, my mechanic says that is
