Check engine light on MAF
Replace the defective part the diagnostics indicated to you. Use standard automotive troubleshooting techniques to verify simple things liek maybe the connector for the MAF is just disconnected/corroded and the sensor may still be good.
[QUOTE=Mister Bally;24661392]Replace the defective part the diagnostics indicated to you. Use standard automotive troubleshooting techniques to verify simple things liek maybe the connector for the MAF is just disconnected/corroded and the sensor may still be good.[/ok, i check the sensor and cleaned it with MAF cleaner and with in 10 check came on again. where can i buy this part whats good website or store i can buy this part. ]
DickieUK
06-05-2007 05:59 PM
KiddJoey
06-28-2001 06:26 AM
