clacking noise due to worn dogbone engine mount?
I brought the TT back to the shop that did my suspension and the mechanic who observed the noise and inspected it afterwards came back with a diagnosis of a worn-out dogbone (torque) mount? Does that sound feasible?
They wanted to charge me around $180 for the part and another $140 for labor. I checked on ECS and this part with the stretch bolts only go for $36. Am I looking at the wrong replacement part?<ul><li><a href="https://forums.audiworld.com/tt/msgs/1770760.phtml">Original post</a></li></ul>
of $40 IIRC. or swap it out completely with a VF Engineering pendulum mount.
the clacking noise could come form other sources...like swaybar links or other motor mounts...even from suspension bearings. how old is your current strut bearings?
I'm not 100% convinced that it's the dogbone mount causing the noise. Should I bring it to another shop to get a 2nd opinion?
Clacking from the motor rocking back and forth is different from the suspension going up and down. I thought you had this isolated? Regardless, you still need to figure out why your shock bolts are at different levels...<ul><li><a href="http://www.suspension.com/volks.htm">http://www.suspension.com/volks.htm</a</li></ul>
millertimeFL
09-21-2006 10:54 AM
allegro
03-17-2003 11:08 PM
