To clay or not to clay...please help
I am about to Zaino for the first time, and I have a dilemma. Should I definitely use the clay bar, or can I get away without it. I have the Z1, Z2, Z5, Z6, Z7, and the clay bar. How important is the bar in the overall process? The car is 6 months old, and I live in Houston, Texas, (ie. no road salt, sand, etc). Thanks for the help
but I have gotten very good results by carefully washing and drying (with Dawn) then going right to the Z1 and so on.
it doesn't matter if you have road salt or not, the claybar should be used anyway. There are other reasons why you should use it. You can pass your hand over an area on the car and if it does not feel as smooth as glass, then you need to use the bar. -Doug
The easiest way to use it is to put the soap all over your car, then get the clay bar out and rub it on the car lightly. You don't have to put much pressure to pick up the majority of the grime. When you are done with the clay bar, just do a quick scrubbing with the soap again.
Make sure to flip the bar around a lot to make sure you are using a clean side.
You will be very happy with how smooth your paint feels.
-Ryan E.
-Ryan E.
It will only add about an hour or so to the process. This way you also get to feel and touch every inch of your car! You will find little pieces of dirt that you never knew were there.
The car will come out much cleaner and should be much shinier once you are through with the entire process.
Have fun and enjoy!
Have fun and enjoy!
Just make certain that you tear off a small piece and work it in your hands to get it soft. Always use small pieces so if you drop the clay you only toss out a small piece and not all of it! The reason you throw it away if it hits the ground is the clay picks up rocks and dirt.
Get a small spray bottle and mix up a solution of Z-7 (1 oz) to about 6-8 oz of water. Shake this and then spray it on small 12-18" sq areas at a time as you rub the clay against the paint. Don't go in circles, go in forward backwards movements on all parts of the car facing the sky and up and down movements everywhere else. This is exactly how the rest of the products are applied, except for the Z-6.
If you have any questions just send me an e-mail.
