Clutch pedal feel survey
The other day I sat in my friends new A4 and rowed the gears. I have to say his clutch pedal was SUPER light.
When I got back to my TT, that clutch pedal felt really heavy. As this is my first manual car, I really don't know what is "standard".
After using the A4, I can't help but think how much easier it is to drive. I think my clutch is stock...
Any opinions? If and when my clutch needs replacing are there clutches out there that are easier to actuate?
and they engage at different points. My Passat with the 1.8T longitudial engine (B5.5/3BG chassis) does take less effort, but engages much further out than the TT clutch.
The reverse is also in the wrong place on the Passat <g>.
be glad it is not a mechanical clutch! Hydraulics today make these very easy to drive....
High performance clutches can make the clutch feel a bit heavier and grab quicker...Personally, i like that feeling...;-)
It doesn't help that my left knee is off/on tender from sports...so the heavy pedal can be a chore sometimes.
mine was light and others I've driven were the same. Someone may weigh in with a light action aftermarket one, but I can tell you it won't be the SouthBend stg III! Currently in my car, it definately requires more effort... sometimes it's tiring (my left leg's a bit weak from an old injury), but mostly it's a non-issue
