code-apalooza
Looks like I need two 02 sensors on top of the Longitudinal Acceleration Sensor. I'll probably pick up another rear O2 spacer from Vast while I am at it...
Will this O2 work or do I need to buy something specific for the AMU? http://www.ecstuning.com/stage/images/dis/7072/600/7072.jpg
Tuesday,19,February,2008,18:01:21:51735
VAG-COM Version: Release 704.1
Address 01: Engine
Control Module Part Number: 8N0 906 018 K
Component and/or Version: 1.8L R4/5VT G 0003
Software Coding: 06710
Work Shop Code: WSC 01236
Additional Info: TRUWT28N811036517 AUZ5Z0A2062098
3 Faults Found:
17526 - Oxygen (Lambda) Sensor Heating; B1 S2: Open Circuit
P1118 - 35-10 - - - Intermittent
17522 - Oxygen (Lambda) Sensor; B1 S2: Internal Resistance too High
P1114 - 35-10 - - - Intermittent
16806 - Main Catalyst; Bank 1: Efficiency Below Threshold
P0422 - 35-00 - -
Readiness: 0010 1001
Thursday,21,February,2008,17:47:09:51735
Address 01: Engine
4 Faults Found:
17521 - Oxygen (Lambda) Sensor; B1 S1: Internal Resistance too High
P1113 - 35-10 - - - Intermittent
P0422 - 35-10 - - - Intermittent
P1114 - 35-00 - -
Readiness: 0000 1000
Address 01: Engine
3 Faults Found:
P0422 - 35-00 - -
Address 01: Engine
4 Faults Found:
P1114 - 35-00 - -
100cell cat, i got lots of those errors....the heating circuit error shows if the signal is not strong enough (hence too far out of the flow)....I was able to adjust the length of my adapter, and viola, no errors and it was working....
Remember, all the second 02 sensor does is read a voltage to confirm that B1S1 is working correctly...moving it away from the flow makes it harder to read...
Just my experience...
