Codes from a friends 99 A4 any advice is great...
sorry i know its not the a4 forum, but its a 1.8t engine and somebody here always seems to have an intelligent answer.
VAG-COM Version: Release 311.2-N
Control Module Part Number: 8D0 907 557 P
Component and/or Version: 1.8L R4/5VT MOTR AT D04
Software Coding: 06251
Work Shop Code: WSC 00001
11 Faults Found:
16684 - Random/Multiple Cylinder Misfire Detected
P0300 - 35-00 - -
16685 - Cylinder 1 Misfire Detected
P0301 - 35-00 - -
P0300 - 35-00 - -
P0301 - 35-00 - -
16686 - Cylinder 2 Misfire Detected
P0302 - 35-10 - - - Intermittent
16688 - Cylinder 4 Misfire Detected
P0304 - 35-10 - - - Intermittent
17708 - Misfire Detected. Probably Reason: Low Fuel
P1300 - 35-10 - - - Intermittent
P1300 - 35-00 - -
17091 - Transmission Range Sensor (F125): Signal too Low
P0707 - 35-10 - - - Intermittent
17953 - Throttle Valve Controller: Malfunction
P1545 - 35-10 - - - Intermittent
coil packs, spark plugs and?
Thank you
11 Faults Found:
P0300 - 35-00 - -
P0301 - 35-00 - -
P0300 - 35-00 - -
P0301 - 35-00 - -
P1300 - 35-00 - -
Thank you
T0M3K
30v V6 Discussion
08-07-2007 06:20 AM
Sir Shnike
01-09-2007 11:14 AM
Nate (ETKA+Scumbag)
03-08-2006 02:11 PM
Imola Ghost
VAG-COM Discussion
04-10-2005 04:20 PM
