Coil Overs question...
i'm planning on getting coil overs for my TT and the guy said that i have purchase camber kit as well to get it back to factory alignment.
has anyone done this?
Kmacs....easy solution...>
<center><img src="http://images.fotki.com/v1/photos/7/7305/63346/Dscf0955-vi.jpg"></center><p><ul><li><a href="http://public.fotki.com/ttschwing/kmac_suspension_install/">Install pics</a></li></ul>
i've had great luck with my PSS9s. for camber you can also go with Forge
they make a lower control arm replacement. it is re-enforced and adjustable. you can then, easily get any camber or lack of, that you want. they pop in in about 30mins. it's a brainless, easy to use system. www.forgemotorsports.com should show you some cool pictures. but yes, you need something to get the car out of too much rear camber. the 2 negatives of it, are excessive rear tire wear (on the inside) and more understeer in the corners (the last thing you want on your TT)
KMAC full kit with the coilovers with allow you to be brought back into factory alignment.
<center><img src="http://www.ttstuff.com/images/KMAC_180.jpg"></center><p><ul><li><a href="http://www.ttstuff.com/performance_suspension.php#camber">K-MAC Rear Camber Kit</a></li></ul>
White LighTTning
9
02-27-2003 05:12 PM
