Coil Pack Issues, Pics of Coil - Can someone assist?
I took out coil back number three, and cleaned the portion that goes in with a damp towel, it was pretty dirty etc. I let it dry etc. I placed the coil pack back in and it went down but is still raised. It wont go down all the way. WHAT in the hell could be the cause of this, it's about a half inch higher then the rest?!? When they go bad, do they do this?
HEre are some pics, maybe this will help :/
<center><img src="http://pictureposter.audiworld.com/75354/dscn0021.jpg"></center><p><img src="http://pictureposter.audiworld.com/75354/dscn0022.jpg">
If you look at the third one over (from the left) you can see it's raised up. What is it you would like me to check? Evidently these have been replaced by AUDI under that recall :/
So 180's had the pop-in kind. It sounds like your plug popped out, or unscrewed.
Have you had the plugs replaced lately? That could also explain why everything is so nasty under there.
The plug can just (pop out?) :X
Revo removed that plug and one other to look at them at TT-east. I assumed they put them back in correctly. If it popped out, that means something is damaged then right?!?
ALSO I just moved the coil from cylinder one, and put it in cylinder 3. It still wont fit, so that has to mean something wrong with the plug I guess. There is all kinds of carbon deposits on the coil and in the area where the coil goes down.
heateris
12
02-01-2006 01:29 PM
