Connecting V1 radar directly to RJ45 Outlet
Is this a safe option? If I put a fuse of the same amperage of the v1's normal fuse in the place of the outlets fuse, would that work?
<center><img src="http://pictureposter.audiworld.com/67197/v1.jpg"></center><p>windscreen down to the fuse box.
If you wanted to go to the RJ-45 plug, you would have to run a longer cord to be invisible or use the coiled cord and you would see it when in use. Also, you need to jump a connector in the trunk (left side access hole) to get power to the jack. = much more work
I have a crimp tool so i can make any length telephone wire I would need, so i really want to use that outlet!
