Control arm bushings question >
"Steve" ;-) I should of course replace the rear bushings at the same time I'm replacing the front's, since the arms need to be removed to do the work. Should the rear's just be replaced with OEM's, or would/could/should polyurethane's be used there as well? Thanks, Will
On the rear. Vortex Joe has been following the info on Vortex and apparently, without the captured metal bushing, they chafe and wear out pretty fast. Fronts are good to do though...you'll get close to Mk1 performance with just them...:-)
other than wheels and underbelly shroud? just looking at manuals right now - car's still in the shop.
