Could I have screwed up the alignment replacing a front CV boot?
I just finished replacing the front outer drivers side CV boot so naturally I had the shock tower disconnected from the lower control arm as well as the tie rod disconnected. Now the steering wheel is cocked to one side but the car does not pull. I checked the tire pressure and it is fine. Thanks!
Re: "shock tower disconnected from lower control arm" ???
There are 3 bolts that hold the strut/ shock to the bottom of the suspension (I call it the control arm, I guess that is wrong) basically the bottom part that holds the hub and wheel on. I moved the strut to the side once it was detached to get at the CV boot.
jwetering
Audi allroad
10
08-29-2013 10:57 AM
NorCalS6
02-26-2007 02:52 AM
CaseyH
12-14-2004 08:45 AM
Big Ern
01-04-2003 11:29 AM
