a couple of questions inside....
1) what fuse did you tap into to hardwire your radar detector? i plan on hardwiring my V1 after work
2) how did you remove the stickers on the visors? my passenger one peeled right off. the driver's side doesn't even seem to be a sticker. i planned on trying goo-gone, but if there's another way, please let me know
3) can someone please link me to the exact model blitzsafe adapter i need to hook my ipod up to my CD changer? i plan on removing the changer. i have an 04. is <a href="http://www.autotoys.com/x/catalog/AUDI_AUX_ADAPTER_TYPE_III_2003_ONLY_p_46.html">thi s</a> the one i need?
the ipod thing's the most important since my iTrip doesn't work in my TT. i don't know why. it will pick up the signal for a second, but then drop it. i've never had that problem in any other cars/locations.
thanks guys!
and i don't care what people say, TT's are greaTT!
thanks guys!
You can ground it using the screw directly to the right of the fuse puller. Make sure the U-connector is between the screw and the washer.
<ul><li><a href="http://www.autotoys.com/x/catalog/AUDI_AUX_ADAPTER_TYPE_I_19982001_AUX_INPUT_ADAPTER _p_31.html">this one</a></li></ul>
i knew there was one that plugged just in the changer spot.
this one works for 04's? it says only up until 01. i just want to make sure before i order it.
TZL
07-03-2002 09:51 AM
