dealer replaced my battery...gave me an extra 1-2psi of boost!
Strangely, after replacing the battery, my VDO boost gauge now peaks out at ~23-24psi...with the old battery, I peaked at about 21-22psi. Why??? I did a TB adaptation when I switched back to APR93 from stock, so maybe that would explain it....nothing else has been changed.
I had A LOT more boost/power after I changed out a completely dead battery. (left the lights on at airport)
I attributed it to the ECU "learning" the right settings again. I think it resets to all the knock, boost, and mix settings to very high levels and then dumbs them down to acceptable levels for knock and reliability.
I could be wrong though...but that seemed to make sense to me.
...your prior adaptation limited the boost to 22 psi...over time that boost ceiling may be the stasis after adaptation.
The Chad (VaultPSU)
9
11-02-2007 05:48 PM
ArTT Vandelay
07-06-2005 08:52 PM
