Del Rio Stg IV is done!!! FINAL results. MONSTER thx to Jeff Moss & GIAC
<center><img src="http://pictureposter.audiworld.com/50555/91_dyno.jpg"></center><p>
got the dynos done on 3 different settings. unfortunately, the car originally had NO CAT or EXHAUST with the dynos i've previously posted. i wanted to do the same but didn't feel like buying a dyno only pipe to bolt onto my dp for just a dyno. and since i do not drive it that way, i dyno'd with cat and exhaust that passed a Cali test. even though the car has much more low end that it used to, the car is actually putting out less boost & power down low than it used to. meaning the cat does lose more power than i previously thought. so maybe i will have a dyno pipe made to see what it truely can produce.
BUT look how flat a power band i now have!!!!
Mode 2 = pump software and 100 octane out of a gas station
<center><img src="http://pictureposter.audiworld.com/50555/pump_100.jpg"></center><p>since you can NOT guarantee all the time what gas you're actually getting I wanted a safe tune for those times. here it is over the 91
.....and finally a Race mode w/ VP109 unleaded you buy in a can.
<center><img src="http://pictureposter.audiworld.com/50555/vp109_dyno.jpg"></center><p>there was still a couple degrees of timing left in the car, but this showed a VERY healthy tune with sub 975 degree EGTs. so doing an entire 20 min session at the track would be fine in this setting!
ALSO, car has 25k on set up, so things are still healthy!
OLD VP race gas with no cat/exhaust and new hardware
<center><img src="http://pictureposter.audiworld.com/50555/nate_delr_11hb_race_pwr_tq_bst_logos.jpg"></center><p>look at now much torque i picked up on the new setup!!!! and how long i have peak power range!
