do you have to bleed all four brakes if you are only replacing the....
front pads and rotors. i searched first.i'm assuming yes but just making sure. i know this is probably a dumb question but please bare with me. thank you
you may want to take the lid off of the brake fluid reservoir and make sure it doesn't overflow as you compress the piston. Depending on how much fluid is in the reservoir and how much you have to compress the pistons you might end up with a bit of a spill, and brake fluid is nasty stuff.
I was taught by very well trained tech's, that to force fluid back to the master cyl is a HUGE mistake. Bleeder should be open when colapsing caliper piston, then install pads reasemble and BLEED YOUR BRAKES !! this serves two funtions 1) to clear air or debris from the line(rubber seals do wear) 2) to allow some fluid to escape the system so you are adding fresh fluid and getting rid of fluid at the caliper that has gone through many heat cycles. heat is the enemy
S4gasm (LoTR)
14
03-16-2005 06:44 AM
CaseyH
07-22-2004 11:15 AM
poopeter-el sigthief
11-30-2002 07:34 PM
maaliish
01-05-2001 08:31 AM
