Does it feel like the rear skips left or right over bumps?
post below, your tires may be worn out and/or over inflated. Also, inspect for worn bushings or other suspension components. YOur car looks like a quattro, is it? This is important info also.
Anyway, check you tire pressures, you may get a suprise.
to side? My car did/does that. I'm told its a suspension/alignment imbalance as the Haldex can't tranfser power side to side as I think I feel it "do". Tires can be worn or ot can be out of alignment spec making it easier for it to tramline and do that. I drove a newer car the other day that didn't have any of these symptoms and it was a night and day difference.
i've had those same symptoms before when my alignment was off... that'd be my first guess
also, your wheels are unbalanced, rubbing, tires unevenely worn, etc could do that too.
Did you recently do suspension or wheels?
