does the timing belt have any 'connection' with the>>>
other pulleys (PS, alternator, flywheel) i guess what i am trying to ask is if the timing belt and the 'serpentine' belt is all tied together in 'one' system
i know they are two diff belts....but are they connected??
before removing or you will have to replace it. Also, it's recommended to replace the water pump and the tensioner as these go bad. The stock water pump has a plastic impeller that breaks and the tensioner looses tension and causes the belt to slip.
Timing belt replacement should be every 60K miles.
it shouldn't have any effect on the 'timing belt' and or the tensioner correct?? since it is two diff system
The serp belt pulley is bolted to the lower TB sprocket, but you don't have to touch the latter to change the former.
That said I don't agree with the idea of lightened/underdrive pulleys for a street car, but, I digress....
said they will cover it if my timing belt goes south...(as long as if i have all my MAJOR tuned up done at a audi dealer ie 15k tune ups)
i just want to make sure that the serp. belt got nothing to do with the timing belts (or tensioner) since i have UR pulleys
go ahead and run your "UR" pulleys.... I'm sure the Audi engineers were on crack when they designed the OE pulleys. The college kids who designed the smaller lightened, titanium, composite, carbon fibre, graphite impregnated replacements know better I'm sure.
asn
05-28-2010 06:54 PM
Ballin'A4
02-25-2009 06:54 AM
