Dont use In Motion Tuning chips!!!
Two years ago I bought ECU Chip tuning on Ebay from In Motion Tuning. I had no issues with it until a month before warranty expired. My car started throwing misfire codes. I replaced all plugs, coils, and inspected harnessfor poorly insulated wires that may have cracked from heat exposure. I finally concluded the problem had to be the ECU. I was shocked when I removed the cover of my ECU to find what a lousy soldering job IN Motion Tuning did with their chip!As you can see from the photo. There was even a pin that was not properly soldered to the board it was just barely making contact! I can only conclude this was the cause of all my problems. By the time I found this the warranty had expired of course! I doubt it would have mattered anyway as another TT quattro owner I spoke with had the same problem under warranty and IN Motion did not fix it upon him returning his malfunctioning ECU to them.
I now have a new ECU that just happened to come with an APR chip
(thanks to my lucky find on Ebay) that looks better than thefactory components soldered to the board!
Sorry I dont have a pic of the quality APR chip my wife deleted it by mistake.
There is a reason why APR charges $500.00 plus for their chips and it tweaks me I had to learn the hard way. In the long run it cost me almost $1500.00 to save 200.00 on my performance chip!
So what have we learned kids? You get what you pay for! Go for the reputable company!
Yeah I have seen some good and bad chips on ebay lately too. I was just going to get a new ECU from the stealership when this happened because I could not locate one that matched my VIN anywhere. When I almost lost hope I found a matching ECU with an APR chip that had Chipped mode, stock and Valet for $350.00! How lucky is that! The faulty chip and ECU I pulled out of my car is currenty on Ebay now. If there are any brave souls willing to try to repair it!
I have an InMotion tune, but I went through the OBD port to reflash my ECU rather than sending it in to bee soldered. It's been fine with the exception of a hard limp once in a while (17743 - Torque overlimit errors).
Gonna try an MBC and diode to try to boost a bit more, too.
Negative459
05-23-2002 08:08 PM
Blizzboy
10-12-2000 10:25 AM
a.robles
01-10-2000 06:22 AM
