Door Open. Lock. Close Door. No Beep.
I used to be able to have the door open (or the trunk), lock the door (via remote), close the door (or trunk) and have the horn beep and lights flash to indicate that the alarm's active. Now when I do this, I get no beep or light flash (I have to lock the door again via remote). I had the keys reprogrammed recenty. Would this be the problem?
-when all of the doors and the trunk are closed and i lock the car via remote, it beeps.
-if i lock the car via remote with the passenger side door still open and/or the trunk and then you close them, it beeps.
-if i lock the car via remote with the driver side door open and then close the door, no beep.
I mean I do the same with the trunk (park the car, open the door, get out of the car, close the door, open the trunk from remote, lock, get the briefcase ouf of the trunk, close the trunk, beep). Never could do that with the door.
go back and have them work that setting back into your puter.
I know that you can also program the keyfob to make the windows go down if you hold the open button down for 3 seconds. BUT this setting over rides something else.. I kinda recall that it overrides the windows going down in an accident. Anyway.. what ever it was the dealer here in the States, would not do it as it is a European spec function, and not allowed in the US as it overrides that Accident function.
All in all... there are many more things that the computer can do, and I am sure that the tech who reprogrammed your keyfob forgot something...
e!
e!
20VTURBOA4
A4 (B7 Platform) Discussion
12-09-2019 07:42 PM
azn123
05-25-2006 02:55 PM
