Dr.Schwing....best place to order a 4 bar fpr??
#15
No need...3 bar is plenty unless you change the equation...
The reason you need the 4 bar is because Velocity goes down with the bigger opening. Reduced velocity, lower MAF signal, leaner ECU calculation. The 4 bar tricks things and brings it all back in line...
#19
more gas = go not so fasTT.........>
Running rich will actually reduce power. You can get the Injectors blueprinted and cleaned for a little over $100/set. Otherwise, maybe some Techron and new plugs??
#20
ok! >
Does that stuff work (techron)? Got new plugs - just waitin' fo' this damn rain to stop - 3 cel's in the last 2 weeks...
But once upon a time my dealer did tell me he needed to either clean or replace the injectors due to crud (carbon) buildup, so I guess I'm there - too much city driving, not getting the engine hot enough.
