Driver side window doesn't have auto down
anymore, it also doesn't roll slightly down when you open the door. The passenger works as advertised but drivers doesn't. Any thoughts?
Its actually in your manual
Should be described in the section that discusses disconnecting/changing the battery.
I believe you hold the button down until the window is all the way open. The hold the button up until the window is all the way up. Release the button, and pull it back up for 1 second.
There seem to be several methods, but this my mechanic's version...
Start w/ windows up and push the switch down and hold 2 sec. after window is fully down.
Pull switch up and hold until window is fully up.
Release, then pull up on the switch twice.
It worked for about a week, then he replaced the window motor.
greedygremlin
A4 (B9 Platform) Discussion
06-27-2018 04:05 PM
QPower95
11-23-2010 09:36 AM
