The DV pick of the litter choice award goes to...
TURBO XS H25.
The initial throttle response is instant w/out delay, maximizes turbo boost pressure and adds higher compression due to its boost adjustability retension. The valve fits perfect and the kit comes w/ a vacuum extension hose and ten washers to evenly match piston spring tension w/ application required boost pressure.
The valve is cast billet aluminum w/ a brass piston designed for longevity. If you think your Forge or Bailey works well, and you think you are optimizing your boost potential, I will bet you will get a rise in your pants if you try this valve which truly will MAXIMIZE your engine HP output potential.
I currently own 3 OEM BOSCH G,H, and N.
Bailey
Forge
Turbo XS
Turbo XS "blows" away the competition. $169.00 value.
I highly recommend it. Superior.
Ciao..
Bailey
Forge
Turbo XS
Ciao..
the PES and Turbo XS type H are one in the same. And looks like I need another washer. I called Turbo XS and the women I spoke was a great help.
She even said they would give me a new valve if I was still exp problems with it. Oh yea, commented that the flutter that I hear is beacase the vacuum is right on the cusp of opening the valve so I think that means I need just a little more tension (read a washer)to make things work smoother.
Kudos to Turbo XS for customer service!
B56
05-17-2007 08:58 AM
audaciousTT
10
11-05-2003 05:35 PM
shadyraven
11-14-2002 09:38 AM
MichaelTT
37
08-15-2000 09:46 AM
