ecs t-belt kit - should I get the pulley as well? Is ECS kit better than dieselgeek? Should I get
a different thermostat? I remmeber people had problems with the thermostat they got in the kit. Sorry about the multitude of questions.
Get the Geek kit you can upgrade to the OEM Thermostat for $20. They also have a very good price ($6) on Pentosin coolant. That's the kit I'm going with I believe..
and that there is no reason to purchase it. Do you agree, or would I be better off buying the upgrated one?<ul><li><a href="http://www.dieselgeek.com/Detail.bok?no=372">http://www.dieselgeek.com/Detail.bok?no=372</a></li></ul>
it has everything you need plus the handy water pump removal bolts which are quite helpful. I didn't bother replacing the t stat since my car hasn't shown any signs of a failing one.
it includes cam seals, but they don't need to be replaced unless leaking. I haven't heard of someone doing the crank seal during the tb change. Unless it was leaking I wouldn't mess with it.
