Electrical gremlins
Electrical gremlins. Main issue
Left turn signal on dash comes on when brake is applied.
Left turn signal flashes at different rate or stops flashing when brake pedal applied.
Brake light warning on dash beeps when applying brake pedal. Turning on parking or headlights eliminates the light warning.
ABS light occasionally comes on then disappears.
Airbag warning light is on.
So far all I have done is confirm light bulbs are ok and Brake switch is operating using VAG block 066. It seems to be ok. What else could be causing the above ? Maybe I need a new ABS controller?
VAG codes pulled:
Sunday,02,December,2012,18:16:18:18804
VCDS Version: Release 11.11.4
Address 01: Engine Labels: None
Control Module Part Number: 8N0 906 018 S
Component and/or Version: 1.8L R4/5VT G01 0004
Software Coding: 06600
Work Shop Code: WSC 01236
VCID: 418747174BC0BE106EB
4 Faults Found:
17977 - Cruise Control Switch (E45)
P1569 - 35-10 - Implausible Signal - Intermittent
18084 - EPC Warning Lamp (K132) Circuit
P1676 - 35-10 - Electrical Malfunction - Intermittent
18098 - Malfunction Indication Light (K83)
P1690 - 35-10 - Electrical Malfunction - Intermittent
18057 - Powertrain Data Bus
P1649 - 35-10 - Missing Message from ABS Controller - Intermittent
Readiness: 0000 0000
Sunday,02,December,2012,18:18:09:18804
Address 15: Airbags Labels: 8N8-909-601.lbl
Control Module Part Number: 8N8 909 601
Component and/or Version: Airbag Front+Seite 1005
Software Coding: 10102
VCID: F7F369CFD584B0A090F
2 Faults Found:
65535 - Internal Control Module Memory Error
00-10 - - - Intermittent
00588 - Airbag Igniter; Driver Side (N95)
127-10 - Unknown Error Elaboration - Intermittent
VAG codes pulled:
4 Faults Found:
2 Faults Found:
Audi for life 1987
14
02-04-2022 12:29 PM
